#65563 - 01/29/21 11:03 AM Order Entry Spec Amount Formatting
JWH Offline
John Hancock, CPA
Loc: London, ON
If the quantity ordered, shipped, backordered or returned is in the thousands can you not format these fields to show "1000" and not "1,000"?
John Hancock
John W. Hancock & Assoc. Ltd.
#65564 - 01/29/21 12:24 PM Re: Order Entry Spec Amount Formatting [Re: JWH]
That is not an option, for some reason. It's a good request.
The only options for the thousands separater are comma, period or space. There should be the option "none"
#65565 - 01/29/21 01:03 PM Re: Order Entry Spec Amount Formatting [Re: Steve Schwartz]
JWH Offline
John Hancock, CPA
Loc: London, ON
Thanks Steve. At least I am not losing it.
John Hancock
#66859 - 09/29/21 04:22 PM Re: Order Entry Spec Amount Formatting [Re: JWH]
Hello Scott and Steve,
This feature has been added in the OrderEntry 93A (2021.09.27) Service Pack:
In the Designer, Properties for Amount fields has a new option for the Thousands separator: None.
#66913 - 10/05/21 05:57 PM Re: Order Entry Spec Amount Formatting [Re: Softrak Support]
JWH Offline
John Hancock, CPA
Loc: London, ON
Thanks support. Now if you can get the shipped quantity added to the auto invoice feature would be great.
John Hancock
#66939 - 10/07/21 12:57 PM Re: Order Entry Spec Amount Formatting [Re: JWH]
Scott, we don't usually add features in Service Packs so your auto-invoice request will need to wait for an Upgrade to OrderEntry. However, the Designer change was a common feature and it was included with other changes made for form printing in OrderEntry.
This Designer feature is also included in the Invoices 9.3B (2021.09.30) Upgrade just released.
#66981 - 10/12/21 12:50 PM Re: Order Entry Spec Amount Formatting [Re: Softrak Support]
JWH Offline
John Hancock, CPA
Loc: London, ON
Thanks support. I hope the Order Entry upgrade comes out sooner rather than later.
John Hancock
#67107 - 10/26/21 10:37 AM Re: Order Entry Spec Amount Formatting [Re: JWH]
JWH Offline
John Hancock, CPA
Loc: London, ON
Support we just loaded the latest Order Entry service pack specifically to get rid of the thousands separator and while we can adjust the spec field now to "None" for this option is still prints out the separator.
Is there some other switch or setting that needs to be done?
John Hancock
#67109 - 10/26/21 11:14 AM Re: Order Entry Spec Amount Formatting [Re: JWH]
Hi Scott,
I've taken a look and for me, though the OrderEntry designer was updated to support the None option for the thousands separator, I also do not see the same output for printing live forms - I also see a comma still. I was going to ask if you had saved the spec after making the change, but that isn't the reason for this.
This common feature for the designer was indeed implemented successfully for the Invoices 9.3B update, but it looks like squeezing it in for the OE released in fact also needed a program change to recognize this as well as the update to the designer. I have let R&D know about this - thank you for bringing this to our attention.
#67113 - 10/26/21 12:17 PM Re: Order Entry Spec Amount Formatting [Re: Softrak Support]
JWH Offline
John Hancock, CPA
Loc: London, ON
Thanks support. Yes I thought originally I had not saved it or was using the wrong spec so I am glad to hear you are getting the same result.
Thanks for posting and will keep an eye out for another update.
John Hancock
0 registered (), 70 Guests and 3 Spiders online.
14666 Topics
