#63290 - 03/11/20 10:18 AM
AP 9.3B (200301) - cannot generate system checks
5 Corgis and Counting
Loc: Baltimore, Maryland USA
Hello, I upgraded a client last week to ap 9.3b. All seemed to complete without incident, we got no errors, etc. However, she now is unable to generate a system check run. She has all of her invoices on hold until she forces them or in control payments. I've tried to do this with her and neither of us had any luck. We applied the hotfix today, even though this issue was not mentioned in the release notes, I thought it was worth a try. No luck. Has anyone else had this issue? Currently she has to do all manual checks and with her transaction volume, this is pretty inconvenient. Many thanks, Carol
Carol Lord Openhym Allegro Automation, Inc. Baltimore, MD USA
#63291 - 03/11/20 10:32 AM
Re: AP 9.3B (200301) - cannot generate system checks
[Re: Carol Lord Openhym]
Adagio Padawan
Loc: Waterloo, ON
Hi Carol,
We haven't installed the upgrade yet, so I can't check this, but often when there are new features the security group setting for that feature is disabled. Maybe the option for her to create system checks is disabled with all the new features now available with system checks.
Lauren
Lauren Stief Stief Group Adagio Solutions and Support 1-800-540-3164
#63292 - 03/11/20 11:00 AM
[Re: Lauren Stief]
Excellent suggestion. Thanks, Lauren. I'll let you know if that was the culprit.
#63299 - 03/11/20 01:27 PM
[Re: Jesse_Gilbert]
Hi Jesse, Thanks for the reply.
Are you talking about the "require check run approval" option in Batch/System Check tab? That one is unchecked...
I've also gone in and made sure that her security allows all functions in Adagio.
#63302 - 03/11/20 02:26 PM
[Re: Softrak Support]
Hi there, Thanks for the reply. What happens is they force a series of invoices via payment control. Then we go to generate a system check batch and it says there are no payments to generate (that is not the exact wording but the client is gone for the day and I'll need to confirm tomorrow). The pre-check register also shows up as blank, nothing to pay.
I went into Payment control and set the columns to display the status of the invoices in the grid. That way I could visually confirm that they are no longer on hold. Once I did that, I tried generating the system check batch and still got nothing. This has been happening since the upgrade.
Also, Data Integrity is clean.
#63304 - 03/11/20 03:06 PM
Hi Carol,
I asked around, and apparently one other site experienced something similar, and it had to do with a flag for only selecting EFT transactions being enabled on the System Check Run screen but hidden because EFT was not enabled in the Company Profile.
If this is the same thing for your client, the way to check this out is to edit the Payables company profile and temporarily enabled Allow EFT. Then edit the System Check Run to see if the option is now visible. If so then turn it off.
Before disabling EFT in the Company Profile, also edit the Banks to make sure nothing got configured there to assign anything related to EFT. In the other site, they had EFT Processing methods set on the banks that needed to be disabled. When everything is cleared out related to EFT, you can edit the company profile and turn EFT off.
If it turns out that this happens to be the solution, and if they have a data backup prior to converting to AP93B, see if you can replicate the conversion issue in your office. It may be that there are pre-93B data conditions that is affecting the conversion, and something in this area for us to fix.
Regards, Softrak Tech Support
#63418 - 03/20/20 01:52 PM
Ok, I think we figured it out. She said this was only happening when she tried to do a check run just for specific vendors. When I checked one of these, I saw that the vendor was on hold.
In the past, vendors on hold could be paid via system check runs if they were forced. With the new version, the only way forced payments can be picked up in a system is to change the vendor status to not on hold.
The work around I've given her is to use payment control to force invoices she wants to pay and then do a system check run with the "Forced" radio button checked. That seemed to work just fine.
What needs to happen is if a vendor is on hold but an invoice is forced, it should be picked up in a system check run. My client has assured me that prior versions did work this way.
Thanks.
1 registered (Tanya_Belanger),
188
Guests and
74
Spiders online. |
14625 Topics
