#629 - 07/17/00 12:38 PM Full Duplex Adagio Invoices
Tony Martin Offline
Loc: Chatham, Ontario, Canada
We are using Adagio invoices. Our laser printer has a duplexer. How would one go about printing standard information on the reverse side of our invoices
#630 - 07/17/00 01:15 PM Re: Full Duplex Adagio Invoices
Hello Tony,
Adagio Invoices does not a function that lets you print on the reverse side of the invoice itself, this will have to be set in the pinter setup.
#631 - 07/17/00 01:35 PM Re: Full Duplex Adagio Invoices
Tony Martin Offline
Can I put a string at the bottom of the footer that calls a PCL macro (this would page eject, print my page [on the back] and then the page footer would issue a new page command.
Essentially, what I'm asking is if I can put control codes in text label fields?
#632 - 07/17/00 01:42 PM Re: Full Duplex Adagio Invoices
Hi Tony,
In Adagio Invoices, whatever you put in the text field, Invoices will print that assuming it is a text.
Also, the "control codes" will be read by Adagio but printed as text.
This will have to be done through the printer setup and driver, Adagio does not have a function to do duplexing.
#633 - 08/31/00 10:28 AM Re: Full Duplex Adagio Invoices
Re: printing on the back of an invoice...
Since Adagio does not support duplex printing, why not use your word processor application to print the "back" of the invoice first, then feed the resulting "invoice forms" into the printer with the blank "front" oriented properly so that when Adagio prints the invoices, the legalese and terms are on the back.
Just a suggestion.
Tom Fahey
