#60871 - 05/13/19 06:35 AM Remittance advices for manual transactions
Janet Offline
Adagio Graduate
Loc: Ontario
(192.186.105.2)
Is there a way to generate a remittance advice when doing a manual payment as opposed to a cheque run?
#60872 - 05/13/19 08:21 AM Re: Remittance advices for manual transactions [Re: Janet]
Dan_Desautels Offline
Loc: Thunder Bay, ON, Canada
(50.72.215.69)
Hi Janet,
Are you looking to generate the advice to an email for an EFT payment?
Dan Desautels
DezTek Solutions Inc.
Thunder Bay, ON
#60874 - 05/13/19 12:38 PM Re: Remittance advices for manual transactions [Re: Dan_Desautels]
Janet Offline
Adagio Graduate
Loc: Ontario
(192.186.105.2)
Yes
#60876 - 05/13/19 01:53 PM Re: Remittance advices for manual transactions [Re: Janet]
(50.72.215.69)
If you have the EFT add-on set up, you should be able to turn on additional forms in the bank set up so that when you create the file it will prompt you to "print additional forms". If you need help setting up the form or the EFT provider, your consultant should be able to help you.
Dan Desautels
Thunder Bay, ON
#60891 - 05/14/19 11:45 AM Re: Remittance advices for manual transactions [Re: Dan_Desautels]
Janet Offline
Adagio Graduate
Loc: Ontario
(192.186.105.2)
Thanks Dan. I have this set up and use it but when you do a "manual" payment say for a single transaction I don't see an option for EFT and therefore there is no advice email either. I'll reach out to my consultant. Thanks again
#60892 - 05/14/19 11:48 AM Re: Remittance advices for manual transactions [Re: Janet]
For anyone else in Janet's situation (can process EFT payments in System Check run but not in Manual Check entry), there is an option in Company Profile to turn on that capability.
#60894 - 05/14/19 12:06 PM Re: Remittance advices for manual transactions [Re: Bruce Gardner]
(50.72.215.69)
Janet,
Ahh...that makes sense then. Bruce has the answer for you. Company Profile under System Options should do the trick.
Dan Desautels
Thunder Bay, ON
0 registered (), 112 Guests and 0 Spiders online.
