#60248 - 03/05/19 09:18 AM OE - ORDER DESIGNER SET-UP
Heather Mac Offline
Good morning,
I'm hoping someone can help, our original template for our invoice order design was three copies (office copy, customer copy and customer copy) and it would print pages in order of 1,1,1 then 2,2,2 and so on. The reason for this was we used three part separated colour carbonless paper all in same print tray, that went white, yellow, pink. My problem is we switched to 2 part carbonless paper which is white, yellow, so I changed my specification options for number of copies from 3 to 2 (see attachment). Once I did this and saved, the pages no longer print in sequence of 1(office copy),1(customer copy), & 2,2. I have tried everything from print settings, to ignore application collate and nothing is working. Please help....
Doc1.pdf (224 downloads)
#60267 - 03/05/19 04:19 PM Re: OE - ORDER DESIGNER SET-UP [Re: Heather Mac]
Hi Heather,
Which version of OrderEntry?
Are you printing a single invoice that has multiple pages, or printing a group of invoices?
There are 2 different ways to define printing multiple copies in OrderEntry 9.3A. One is the way you indicated, on the Specification Options of the form spec. In the case of printing a multi-page document, it would always collate with all the pages of copy 1, followed by all the pages of copy 2.
The new way is a Number of Copies field directly on the Print Invoice screen, instead of the spec. The purpose of this is to print X copies of page 1, followed by X pages of page 2, and so on. A downside of using this place is that the value is not remembered (and will be reset to 1 for the next printing), which is likely not desirable in your case.
The other possibility is to define the number of copies on the Windows Printer driver, and make that driver the default when printing forms from OE.
You may want to connect with your Adagio consultant to investigate your options.
0 registered (), 512 Guests and 3 Spiders online.
14651 Topics
