#59772 - 01/18/19 11:08 AM PO 9.3A (171107) Auto Generate PO from OE
A client uses this feature regularly.
There is one item for which they always have to override the item description when they enter the item on a sales order.
When the item gets pulled into a PO, the PO grabs the default item description instead of sales order's (overridden) item description.
Is there a way to tell the system to use the item description per the sales order?
#59781 - 01/18/19 06:10 PM Re: PO 9.3A (171107) Auto Generate PO from OE [Re: Steve Schwartz]
Hi Steve,
Not at this time. I will write up the request for R&D.
#59783 - 01/19/19 10:38 AM Re: PO 9.3A (171107) Auto Generate PO from OE [Re: Softrak Support]
Steve:
Just in case you don't know:
If you use the "Import OE Lines" the item description changes are retained.
#59787 - 01/19/19 12:45 PM Re: PO 9.3A (171107) Auto Generate PO from OE [Re: Douglas Dickie]
Yes I suggested that to the client. But they use “min/max” levels so that won’t work.
0 registered (), 153 Guests and 1 Spider online.
14666 Topics
