#57499 - 05/16/18 02:17 PM Print multiple batches in Ledger
I used to be able to select multiple batches and do a "Listing" to print them all in one shot. Now when I select more than one batch, "Listing" becomes greyed out. Is there a setting somewhere to change it so that I can print multiple batches in Ledger again?
#57500 - 05/16/18 03:06 PM Re: Print multiple batches in Ledger [Re: SusanTennier]
Hi Susan:
I can multi-select a number of batches and the "List" button doesn't get greyed out as long as they are in sequence (contiguous). I'm using Ledger 9.3A (2018-04-22). I just checked 9.2B and it had the same behaviour.
#57501 - 05/16/18 03:15 PM Re: Print multiple batches in Ledger [Re: Bruce Gardner]
Hi Susan,
Is your batch list sorted by Batch number or Description? If sorted by Description, then you will see the Listing button disabled when multi-selected batches because there is no guarantee that the batch numbers will be consecutive.
#57502 - 05/16/18 03:59 PM Re: Print multiple batches in Ledger [Re: Softrak Support]
Okay, that's the problem! Somehow it was changed to sort by description. I've changed it back to batch numbers, so it should be good now. I'll check tomorrow when I have more batches. Thank-you!
