#56207 - 01/31/18 12:51 PM Validating the State/Province Field
If Format Address box is ticked when entering a Customer, Vendor or Contact, why can't the system validate the State/Province, making sure at the very least that it's only 2 characters and all letters (and CAPS)?
Or if that's going to cause a problem for some users, make it an option.
#56209 - 01/31/18 12:59 PM Re: Validating the State/Province Field [Re: Steve Schwartz]
Hi Steve,
That's what the 'North American Address' and 'Uppercase state/province' options in the AR or AP company profiles are for. They validate the state or province in exactly this way.
Edited by Softrak Support (01/31/18 01:00 PM)
Edit Reason: more info
#56211 - 01/31/18 01:06 PM Re: Validating the State/Province Field [Re: Softrak Support]
It doesn't work for Contacts. It really ought to.
Edited by Steve Schwartz (01/31/18 01:09 PM)
#56228 - 02/01/18 11:22 AM Re: Validating the State/Province Field [Re: Steve Schwartz]
My client showed me that for their data, even with the settings properly set, it still doesn't validate. I replicated this on my computer with their data.
I will upload it to. Let me know what is different between their data and the sample data.
#56230 - 02/01/18 12:14 PM Re: Validating the State/Province Field [Re: Steve Schwartz]
Hi Steve,
Thank you for uploading the data; it was useful.
I do not know if this is by design or not, but the Validate State/Province option does not kick in when the Country field is blank. Your client does not fill in the Country code, but Sample Data customers do. That is the difference.
It doesn't seem like this option should rely on a value in the country code to perform the validation, so I will certainly forward your comments on to R&D.
The workaround would be to put USA into the country field.
#56232 - 02/01/18 12:27 PM Re: Validating the State/Province Field [Re: Softrak Support]
Wow, I never would have guessed! I've made it a habit to remove the USA's, even though they are suppressed. Now I have to put them back.
That would explain why the Contacts don't validate - because almost no one goes out of their way to enter the country in a Contact record..
This really needs to be fixed.
#56233 - 02/01/18 01:10 PM Re: Validating the State/Province Field [Re: Steve Schwartz]
Hi Steve,
I talked to R&D, and they said the Country field (currently) has to be non-blank for this to work, because validation has to know whether the list of US states or Canadian provinces should be used. An error will occur if the country is USA but a valid province code like BC or ON is entered. Or vice versa for a country Canada and a valid state code like PA.
I presume that sometimes/often in US sites, the country code is not used for customers or contacts because it is assumed that all/most customers are in the US. Is this a reasonable assertion?
I have suggested to R&D to use the Home Country field in the Company Profile as a fallback if the customer/contact record has a blank country, for the purpose of state/province validation. I don't know if this is technically possible, but I will find out from R&D.
#56236 - 02/01/18 03:06 PM Re: Validating the State/Province Field [Re: Softrak Support]
Support:
I was thinking that in the CP for Vendor Options, if we had a default Country this would go a long ways to solving this problem. Even in Canada, 90% of the vendors are typically in Canada so this would be useful to Canadian users as well.
Also the likelihood of entering BC for a US customer or visa versa is slim. In other apps I've seen North American validation include a combined approach including all states and provinces so that you weren't forced to pick a country first.
#56238 - 02/01/18 03:32 PM Re: Validating the State/Province Field [Re: Douglas Dickie]
I strongly agree with Douglas, both his suggestion to have a default Country in CP, and his suggestion to include a combined approach.
There has to be a way to allow validation without forcing someone to enter a country code. That is just too much to ask of the average data entry clerk.
Sometimes, even if a program works "as intended", the end result is just not acceptable. This is one of those cases.
#56239 - 02/01/18 03:35 PM Re: Validating the State/Province Field [Re: Douglas Dickie]
Thanks for your thoughts Doug. I'll include these with the original report.
Canada vs US: Just considering accidental typos - eg. MN and MB are both valid, with one character different that are next to each other on the keyboard.
0 registered (), 186 Guests and 1 Spider online.
14606 Topics
