#55785 - 12/13/17 11:27 AM
BR Import File size
BR 9.2A 170720 Is there a limit for the size of a statement.csv file?
We tried to import a 505 lines statement and the import crashed with an Access Violation error message.
Split up the file into two smaller files and it imported correctly.
#55795 - 12/13/17 03:16 PM
Re: BR Import File size
[Re: Softrak Support]
This is super weird. I copied and pasted from Notepad to Notepad. When I copied the whole file, the error persisted. When I split the file to smaller chunks with notepad as well, it worked.
#55796 - 12/13/17 04:59 PM
[Re: Patricia B.]
Hi Patricia,
I had someone look at the file, and the problem is that there is no CR/LF (carriage return/line feed) character at the end of the last line of the file. If you open the import file with Notepad, position the cursor at the very end of the last line, press the Enter key to add a return, and save this change, then the import will complete with no errors.
Likely while you were copying/pasting a portion of that file while testing, you were also copying the CR/LF of the last line, which is why it worked.
Regards, Softrak Tech Support
#55797 - 12/14/17 10:08 AM
Thank you. I will ask the client to use another type of file or manually fix the file downloaded from the bank site. It may also be that the file is copied when it is still opened.
0 registered (),
66
Guests and
Spider online. |
