#55538 - 11/02/17 01:03 PM Lower Case vs Upper Case Invoices
The duplicate invoice feature doesn't check for invoices numbers entered both in Lower Case and Upper Case. Is there any option to make all Invoices numbers Upper Case as there is one for the Manual Checks numbers?
AP 9.3A
#55539 - 11/02/17 01:05 PM Re: Lower Case vs Upper Case Invoices [Re: Patricia B.]
The Caps lock key?
Nothing else in Adagio for document numbers, only master records like vendor number, customer number, etc.
#55540 - 11/02/17 01:21 PM Re: Lower Case vs Upper Case Invoices [Re: Softrak Support]
The Caps lock key is a workaround but it would be much better if all the documents are automatically entered as Upper case.
#55541 - 11/02/17 01:26 PM Re: Lower Case vs Upper Case Invoices [Re: Patricia B.]
Suggestion forwarded to R&D.
#55543 - 11/02/17 02:49 PM Re: Lower Case vs Upper Case Invoices [Re: Softrak Support]
Support:
Either that or when checking for a duplicate document number Adagio needs to treat lower and upper case letters as if they were the same thing.
#55544 - 11/02/17 02:51 PM Re: Lower Case vs Upper Case Invoices [Re: Douglas Dickie]
Yes I wrote up both suggestions.
#66494 - 07/08/21 03:47 PM Re: Lower Case vs Upper Case Invoices [Re: Softrak Support]
Hello Patricia,
A new Company Profile option has been added to address this in the Payables 9.3C (2021.07.06) Upgrade released today.
0 registered (), 248 Guests and 2 Spiders online.
14666 Topics
