#54453 - 07/24/17 11:59 AM Payables Program Shuts Down
DenisV Offline
Stranger
Loc: Pitt Meadows, BC
When I try to print a batch listing in Accounts Payable the program shuts down and I get the following error message: "Adagio Payables has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
My workstation is running Windows 7 Professional and my Payables version is 9.3A (170623).
Just wondering if anyone has any suggestions as to what may be causing this.
Thanks.
#54455 - 07/24/17 01:11 PM Re: Payables Program Shuts Down [Re: DenisV]
Is this only when you print a batch listing? Can you print any other reports? Can you print the batch listing in the sample data?
#54456 - 07/24/17 03:14 PM Re: Payables Program Shuts Down [Re: Retired_Guy]
DenisV Offline
Stranger
it does the same thing regardless which report I try to print. I tried printing in the sample data and it worked fine.
#54457 - 07/24/17 03:31 PM Re: Payables Program Shuts Down [Re: DenisV]
Hi, Denis,
Thanks for that extra information.
Is integrity clean? This might be a good time to contact your Adagio consultant.
#54472 - 07/25/17 02:15 PM Re: Payables Program Shuts Down [Re: Softrak Support]
DenisV Offline
Stranger
Yes, the integrity check came back with no errors. I will contact our consultant to see if she can help.
Thanks.
#54474 - 07/25/17 04:14 PM Re: Payables Program Shuts Down [Re: DenisV]
Is there any error message that displays before the program quits?
#54490 - 07/28/17 09:51 AM Re: Payables Program Shuts Down [Re: Retired_Guy]
DenisV Offline
Stranger
The error message says: "A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available." Then there are two buttons; Debug and Close. When I click the Debug button it just says, "An unhandled Win32 exception occurred in payables.exe
0 registered (), 566 Guests and 0 Spiders online.
14567 Topics
