#53474 - 04/25/17 01:53 PM Restrict to subledger option not staying
Lyndon_Olfert Offline
Loc: Winnipeg
In Ledger 9.2B we have set an account as restrict to subledger (restricting to Payables) using the SYS user. Upon exit of the dataset and return to the dataset the check mark disappears. Signing in as a different user also shows no check marks for that account.
Permissions are set for both users to "allow all"
Has anyone run into this problem?
Lyndon Olfert, CPA, CGA, CAFM
#53477 - 04/25/17 04:27 PM Re: Restrict to subledger option not staying [Re: Lyndon_Olfert]
Hi Lyndon,
Nobody has reported a problem to us regarding this setting not being saved correctly, and I cannot duplicate this in sample data and Ledger 9.2B (2017.03.20). Being able to set this is not particular to a security setting, as if the user is allowed to edit accounts, then that user will be able to edit the Restrict to Subledgers option and select the various subledgers on the special tab.
On the account master record, there is a field labeled 'Restrict to source codes' that you can add to the account grid with the column editor. If you edit an account and enable 'Restrict to subledger' and one or more programs, when you save the change, is the value of this field Yes or No on the grid? If Yes, then the value is being set correctly - and if editing the account again shows the checkbox off, then that value is being reset for some reason. If No, then the account is not being updated with the change. Remember that I cannot duplicate either or these in sample data.
#53480 - 04/26/17 07:24 AM Re: Restrict to subledger option not staying [Re: Softrak Support]
Loc: Winnipeg
I edited the grid as you indicated and performed the same actions today and the settings stayed and were displayed properly. Maybe yesterday was a bad day for restrict to subledgers wink
Thanks for your help.
1 registered (Samuel Kopstick), 102 Guests and 3 Spiders online.
1869 Members
14602 Topics
