#5305 - 10/12/05 07:11 PM Workstation performance
Lars Offline
Loc: Vernon, B. C.
I'm having a performance issue with a couple of clients running Adagio from workstations. One in particular has a fairly large database and a lot of horespower on the workstation, including 1G RAM, 1G n/w switch and NIC. Using a P4-266 processor. As suggested by a collegue, all anti-virus protection on the workstation and server are turned off. When doing an inventory search, the time to search is 3 - 4 times as long as it takes doing the same search directly on the server.
Any suggestions as to where the 'bottleneck' would be?
Lars
#5306 - 10/12/05 07:58 PM Re: Workstation performance
Hi Lars,
The most common 'bottleneck' is the server connection to the workstation - it's often way faster to access data 'locally' than to the network. If you copied the data to the C drive and performed the same steps (likely similar to the test mentioned by working directly on the server), you will notice a significant saving in processing time.
So things to look at are the hubs and switches and cards being 100MB/sec rather than 10 - any one can get in the way. Also remember that you can never get data access over the network to have comparable performance than local data access.
#5307 - 10/13/05 01:10 AM Re: Workstation performance
Hello Lars,
Just a note that you'll never get the same performance on a workstation as you would get on a server, because data can be cached on a server, but must be retrieved to the workstation (in case it has changed). This is one of the issues that GridView Server addresses.
1 registered (Warren Karges), 140 Guests and 2 Spiders online.
14673 Topics
