#5283 - 09/26/05 11:33 AM Customer Notes in Receivables
Hi:
We have a Receivables database in which we are having difficulties with the Customer Notes.
If a user double-clicks on an existing Notes transaction, 1 of 3 things happens:
1) View/Edit Note normally
2) Blank Note (Date/Time correct)
3) Wrong Note (Date/Time correct)
By "Date/Time correct" I mean that they match what is shown in the grid container. The more recent transactions seem to work normally.
DIC is clean. Receivables 8.0A (050912).
Has anyone else experienced this?
#5284 - 09/26/05 12:10 PM Re: Customer Notes in Receivables
Hi Bruce Gardner,
I think we're going to need a copy of the dataset in order to see what's going on. Can you have it uploaded to http://www.softrak.com/dbr and let us know when it's there?
Andrew
P.S. I'm assuming that CHKSYS.EXE is clean and that the same behaviour is seen on a local copy of the data.
#5285 - 09/26/05 02:43 PM Re: Customer Notes in Receivables
Andrew:
I have uploaded the dataset to Carleen at 11:40AM your time.
CHYSYS is error-free. I should perhaps point out that this data-set is running on Windows 98 in case that makes a difference.
#5286 - 09/26/05 04:32 PM Re: Customer Notes in Receivables
Hi Bruce Gardner,
You're right, I get the same behaviour. I'll have R&D take a look and see if there's anything obvious.
Thanks for bringing this to our attention.
#5287 - 09/26/05 05:51 PM Re: Customer Notes in Receivables
Hello Bruce Gardner,
Something (perhaps a Rebuild during a Data Integrity Check), deleted all your notes prior to September 22/23. You will need to go back to a backup made prior to then and re-enter the notes. (GridView could be a big help here.)
Sorry the news isn't better. I've made a note that the integrity check should have at least complained about the missing records.
0 registered (), 129 Guests and 2 Spiders online.
14667 Topics
