#52542 - 02/02/17 02:35 PM ap pre check register
Jenny Offline
Stranger
Loc: bc, canada
Since upgrading to 9.2, the pre check register is not pulling any invoices into the print/post checks and advise.
#52544 - 02/02/17 02:48 PM Re: ap pre check register [Re: Jenny]
Don Wise Offline
Adagio Expert
Loc: Ottawa
Jenny,
Double check the Print/Post Checks and Advices dialogue box, especially the starting and ending dates to ensure that invoices are not being included because they don't fit the parameters.
Don Wise
Westboro (Ottawa)
#52546 - 02/02/17 03:01 PM Re: ap pre check register [Re: Jenny]
Jenny Offline
Stranger
Loc: bc, canada
How long does it usually take for a response ?
#52547 - 02/02/17 03:04 PM Re: ap pre check register [Re: Jenny]
Hello Jenny,
No response time is guaranteed on this Forum - if you have an urgent need for an answer you should contact your Adagio Consultant.
Having said that, getting a reply to your question in under 15 minutes, and this reply in under 5 minutes seems pretty reasonable to me.
Don identified the most common reason for no invoices being selected for payment in a system check run.
#52548 - 02/02/17 03:15 PM Re: ap pre check register [Re: Don Wise]
Jenny Offline
Stranger
Loc: bc, canada
All looks good on the dialog box. I ran a pre check on Tues with our old version and it was good. Now nothing is pulling in
#52552 - 02/02/17 04:08 PM Re: ap pre check register [Re: Jenny]
Hi Jenny
Responses are quicker when the question is clear. Yours isn't. ("pulling any invoices into the print/post checks and advise") and you also didn't bother to mention the version number (there is 9.2A and 9.2B), nor the release date (eg 161208) nor what version you upgraded from.
I generally put effort in replying to questions commensurate with the amount of effort the poster has put into making the question clear. Of course I don't work for Softrak so I am a total volunteer on this forum.
#52560 - 02/03/17 08:18 AM Re: ap pre check register [Re: Steve Schwartz]
Jenny Offline
Stranger
Loc: bc, canada
Hi Steve, I thought I was pretty clear but this is my first time on this forum. Let me try again.
I am trying to run a cheque run using 'Check Run'. When generating the 'pre check' report, there is no invoices and it comes up as $0.00.
I have tried it multiple ways with different report groups, vendors, etc with no success.
We upgraded to the 92B version so I am not sure if there is a new setting or a permission that is required that didn't transfer from the previous version.
#52563 - 02/03/17 08:59 AM Re: ap pre check register [Re: Jenny]
Jenny:
More than likely one of your choices is excluding all results, so make sure that all selection criteria are set to:
- from blank to zzzzzz
- .01 to 999,999,999.99
- Due date on or before = today's date.
If there is any outstanding invoices in your system to pay then this should be on the pre-cheque register.
I'm assuming that you have confirmed, via the Open Payables report, that there are in fact invoice outstanding and due for payment.
If this doesn't resolve your problem then you really need to get your Adagio consultant take a look with you to figure out what is going wrong.
#52572 - 02/03/17 11:09 AM Re: ap pre check register [Re: Douglas Dickie]
We chatted with the consultant, and the issue turned out to be that the 'Include Bank with Control Account Set' option was unexpectedly enabled in the Company Profile. Since none of the control account sets had this bank attached, then meant that none of the vendors could be paid from this bank. Unselecting this option was the solution.
#52573 - 02/03/17 12:46 PM Re: ap pre check register [Re: Softrak Support]
Softrak:
Thanks for the update. I'd bet no one would have guessed that answer based on any possible question posted on the forum.
1 registered (Samuel Kopstick), 193 Guests and 1 Spider online.
14623 Topics
