#5249 - 09/13/05 04:30 PM Order History conversion restart
I have recently installed Adagio Order Entry and went through the process where it converted my Softline O/E Invoice History data into Adagio Order Entry history. My problem is I apparently didn't set the Purge After N days in the Company Profile for History data and now the system has discarded all but the last 90 days of my history. I would like to "restart" the conversion so that my history data will be complete. I'm guessing that there is a set of files that I can delete and when I go back into Adagio Order Entry it will convert the history data again.
#5250 - 09/13/05 06:17 PM Re: Order History conversion restart
Hi Larry,
You are correct that you can remove the Adagio OE historical files and restart, allowing you to bring back the Softline Invoice History data. Just make sure that the orders and invoices you have posted in Adagio still exist in the current file (ie haven't been purged yet) - you cannot get these back, short of restoring the entire Oe database.
The Historical files are prefixed with OEHH or OEHL (header and details) - there are quite a few of them. Be careful not to remove any of the OEHEAD* data files, as these are used for current transactions.
Day End Processing does not purge history; you must have run the Purge History function and not realized the dates.
14617 Topics
