#52069 - 12/19/16 10:21 AM PO # disappears after copying it
A client called because their PO has disappeared after copying it.
PO 9.2B 161028
We found that the PO has disappeared from the Incomplete Active Orders filter but not from the PO file.
Refreshing the filter makes it reappear.
#52071 - 12/19/16 11:03 AM Re: PO # disappears after copying it [Re: Patricia B.]
Thanks for posting this Patricia.
Disabling a filter and then rechecking the grid for a missing document(s), account, vendor, customer, etc. is something everyone should be aware of and doing. Using the Refresh Scan button is also something to remember.
This is a good reminder.
#52074 - 12/19/16 12:15 PM Re: PO # disappears after copying it [Re: Softrak Support]
However, it should not be removed from the grid.
#52077 - 12/19/16 01:34 PM Re: PO # disappears after copying it [Re: Patricia B.]
Hi, Patricia,
Seems there's more to this than what is in your post.
When I do this with the same release as you or the site are using and also with the current shipping (161129) release of PO and with the same filter active, in neither case does the PO disappear from the grid -- not the one being copied nor the one it's being copied to.
I'll do some more looking though.
#52079 - 12/19/16 02:49 PM Re: PO # disappears after copying it [Re: Softrak Support]
The issue happens after printing the new PO.
It also happens in the current version PO 9.2A 161129
#52080 - 12/19/16 02:52 PM Re: PO # disappears after copying it [Re: Softrak Support]
Always that little bit of missing information smile
Thanks Patricia. I'll check this out as soon as I have a moment.
#52081 - 12/19/16 03:25 PM Re: PO # disappears after copying it [Re: Softrak Support]
Hi, Patricia,
Want you to know I'm writing up an issue for R&D. Thanks for bringing this grid refresh issue to our attention.
#54713 - 08/23/17 08:43 AM Re: PO # disappears after copying it [Re: Softrak Support]
Hello Patricia,
This has been fixed in the PurchaseOrders 93A 170821 Upgrade.
1 registered (Tanya_Belanger), 225 Guests and 4 Spiders online.
14589 Topics
February
