#51973 - 12/10/16 05:57 PM P.O. Conversion Error
Bill L. Offline
Loc: New Brunswick, canada
Attempting to convert from P.O. 9.2A to 9.2B.
Have 3 sets of data to convert. .
DIC completed with no errors in all 3 sets of data.
One converted with no issue.
Have an error in the other 2 sets.
This is the error:
"The new PO audit file already exists. The file is being removed and replaced with a new converted version."
Click on OK
Then get the following:
"Unable to open data file P/O Audit file @u92AAAJ, (1213)"
Conversion then terminates and request restore from backup.
#51984 - 12/12/16 09:09 AM Re: P.O. Conversion Error [Re: Bill L.]
Hello Bill,
You didn't say which release of 92B you were using.
In the 92A datasets, are there IRAUDIT.{ext} files? If there are, please remove them and try converting again.
#51989 - 12/12/16 11:40 AM Re: P.O. Conversion Error [Re: Softrak Support]
Bill L. Offline
Release is (161129).
Tried removing the 2 IRAUDIT.EXT files but still had the same error.
One new IRAUDIT file was created during failed conversion.
Bill
#51994 - 12/12/16 03:57 PM Re: P.O. Conversion Error [Re: Bill L.]
Hi Bill,
There aren't any outstanding issues with PO conversion.
If you removed the problem files prior to trying conversion again, it should have worked.
To proceed with the investigation, Tech support will need to see the problem dataset.
0 registered (), 135 Guests and 5 Spiders online.
14624 Topics
