#51983 - 12/12/16 09:27 AM Financial Reporter Read-Only Mode
CarlosC Offline
Adagio Fan
Loc: North Bay, ON, Canada
Currently we are using the Financial Reporter shortcut in /SOFTRAK\Ledger\LedgerFinRep.exe to open Financial Reporter, however we have noticed that it seems to always open in edit mode. Is there a way to have it only open in read-only mode?
I know with GridView I had to put a /c in the target line in properties to get it to open in edit mode so I'm hoping the opposite could be entered into the Financial Reporter.
Thanks.
#51995 - 12/12/16 05:57 PM Re: Financial Reporter Read-Only Mode [Re: CarlosC]
Hi Carlos,
Yes, being able to open the Financial Reporter directly in the Print-Only mode, rather than the Maintain/Edit mode, is possible. But it is not done by a shortcut parameter.
Rather, this is configured by the Security Group setup within Adagio Ledger. If a security group assigned to the User opening the Financial Reporter does not have security rights to Maintenance / Maintain Financial Reports, but does have security rights to Reports / Print Financial Reports, then when that user opens the Financial Reporter, it will be in the Print-only mode.
If you don't use security groups for that company in Adagio Ledger, then all users will have full access to the Financial Reporter in Maintain/Edit mode, just like if that user logs into Ledger first and then wants to open the Financial Reporter. Security is identical whether it is opened from a shortcut or from within Ledger.
