#51627 - 11/14/16 08:56 AM Unable to print any reports
Has any one seen the attached error message before?
I am unable to print any reports, all StandardReports folder are present in each module folder and I even tried to swap out those folders for each modules with that of another site to see if that worked.
The folders were created during a new install and the server 2010. Invoices are able to print just not reports.
Can anyone help with this?
PRINTING PROBLEM.png (132 downloads)
#51632 - 11/14/16 10:31 AM Re: Unable to print any reports [Re: GT]
Hi, Ishana,
Have already responded to your email but need to respond here as well.
Haven't seen that error in some time. Please do the following:
- Running Softrak\System\ChkSys.exe on a problem w/s should tell you what part(s) of the Crystal/ODBC components is having a problem.
- Ensure a w/s having the issue can run a File | User Preferences, Listing report. Being able to tells us that the Crystal component of the install is okay, but that Crystal isn't able to make a connection to the AdagioODBC.
- Check that the msvcr110.dll and msvcp110.dll's are in the w/s's (that are having the problem) Windows\SysWOW64 folder (all of their w/s's are 64-bit).
- As they recently moved to a new server, I suspect there was some copying going on rather than just installing. Please also check that the Softrak\System\System.ini doesn't contains only valid drive and UNC references for the new server.
1 registered (rah), 90 Guests and 3 Spiders online.
14586 Topics
February
