#51364 - 10/27/16 08:52 AM Order completed? field value problem in Adagio OE
Vlad Maksymiv Offline
Adagio ADP
Loc: Toronto, Canada
Here is scenario to reproduce the problem:
Create order in Adagio and ship MORE then Qty ordered. Save order. Create invoice from this order.
Order completed? field in original O header record is set to true
Order completed? field in invoice I header record is set to false
Why the values are not consistent ?
Vlad Maksymiv
www.lenmax.com
#51371 - 10/27/16 12:06 PM Re: Order completed? field value problem in Adagio OE [Re: Vlad Maksymiv]
Hi Vlad,
I can replicate this behaviour that you indicated. I will forward your comments along to R&D.
I don't believe that OrderEntry uses the 'Order Complete' value on invoices and credit notes, apart from being able to display it on the grid. This is the most likely reason for the difference, since having No doesn't adversely affect any processing in OE. Do you use this field value on invoices for your applications?
#51389 - 10/28/16 06:29 AM Re: Order completed? field value problem in Adagio OE [Re: Softrak Support]
Adagio ADP
Hello Support,
My client is trying to use combination of both flags for the backorder processing report
Vlad Maksymiv
www.lenmax.com
#51390 - 10/28/16 06:36 AM Re: Order completed? field value problem in Adagio OE [Re: Vlad Maksymiv]
Adagio ADP
Another problem that the client is bringing:
The absence of the mechanism to force the order completed? (by OE user) flag to be true
to prevent further backordering. In over words: force order complete.
(Please not that method of deleting backorder details is not acceptable )
Does Softrak has any intent to improve backorder mechanism in OE ?
Vlad Maksymiv
www.lenmax.com
#51398 - 10/28/16 11:46 AM Re: Order completed? field value problem in Adagio OE [Re: Vlad Maksymiv]
If your remove the backorder quantities, the order is set up as completed. Then, you have quantity ordered and the quantity shipped to know what was not shipped.
0 registered (), 50 Guests and 0 Spiders online.
1865 Members
14467 Topics
