#51304 - 10/20/16 12:59 PM Error Code: 1501 on ToXLSaveWorkbook
Hugh Offline
Loc: Victoria, BC Canada
Hi!
Trying to file:export:transactions and I get
The work around is exporting as a .csv, but it'd be better if it just worked... any thoughts?
#51305 - 10/20/16 01:32 PM Re: Error Code: 1501 on ToXLSaveWorkbook [Re: Hugh]
Hi Hugh,
What program and version are you using, and what function are you doing to get this error?
In the August 10, 2016 service pack for Adagio Ledger 9.2B, this particular error was identified and fixed. This is from the release notes:
In Ledger 9.2B, the Export Account Budgets and Export Reallocations functions displayed the error “Error code: 1501 on ToXLSaveWorkbook” if you exported to .xls format instead of .xlsx.
If you are getting this error from Ledger 9.2B, the solution is to install the service pack.
#51308 - 10/20/16 02:02 PM Re: Error Code: 1501 on ToXLSaveWorkbook [Re: Softrak Support]
Hugh Offline
Running Ledger 9.2B so I'm pretty sure I'm as up to date as I can be... that said, I forced the save path to end in .XLSX instead of .XLS and that corrected it. Thanks for the tip!
0 registered (), 150 Guests and 1 Spider online.
14672 Topics
