#49176 - 03/05/16 03:49 PM Crystal Report 2013 SP7
MarlonMF Offline
Loc: Los Angeles, CA
I'm re-creating some of our custom reports using Crystal Report 2013 SP7 and for some reason every time I add more than one table it crashes. There is no issue if I'm only using one table. Any thoughts?
Marlon
#49177 - 03/05/16 07:05 PM Re: Crystal Report 2013 SP7 [Re: MarlonMF]
Hi Marlon:
I saw the word "re-create" in your question. If "re-create" means "start from scratch" then this PDF document from Softrak could be useful: Converting Crystal Reports to version 2013
#49178 - 03/05/16 10:29 PM Re: Crystal Report 2013 SP7 [Re: Bruce Gardner]
MarlonMF Offline
Thanks for your response. I've already used the document you provided and converted most of my custom report but some are either not picking up the 9.2 version of the tables or not working (no results on the report). I tried to check the table link on the converted custom reports but it keeps crashing every time I click on the link tab to check.
Any thoughts on why it would error/crash when selecting multiple table? Should I buy and use Crystal Report 2011 instead?
Marlon
Edited by MarlonMF (03/05/16 11:16 PM)
#49179 - 03/06/16 12:25 AM Re: Crystal Report 2013 SP7 [Re: MarlonMF]
The failure to look 2 tables is a bug in Crystal. Try downloading and installing the System Updater from our web site.
#49180 - 03/06/16 06:51 PM Re: Crystal Report 2013 SP7 [Re: Retired_Guy]
MarlonMF Offline
Can you please post the link for the system updater?
I can't seem to find it in the clients portal download.
Marlon
#49181 - 03/07/16 07:12 AM Re: Crystal Report 2013 SP7 [Re: MarlonMF]
Hi Marlon,
I have sent them to you by email, although consultation with the office has indicated that this is unlikely to resolve your problem which is due to VLE.DLL not being registered by the Crystal install on some machines only.
Try re-installing Crystal as Administrator. If that fails to correct the problem, try Googling the error.
Edited by Andrew Bates (03/07/16 10:20 AM)
Edit Reason: SysUpdater doesn't fix this problem.
0 registered (), 382 Guests and 2 Spiders online.
14627 Topics
