#48533 - 01/13/16 04:05 AM Multicurrency 9.2A Rate goes to zero
Clients just did their upgrades and upon invoicing in OE noticed that after the first couple of invoices that the rate for the customer goes to zero. (See attached)
Can anyone explain this? The client has to keep logging out of the system but only to log back in and do a couple more invoices.
We tried looking at rights issue there was none, check to ensure the upgrades were done correctly, they were. Also tried to delete and re-create the rates. Checked using the SYS admin user and password but it didn't seem to affect SYS user. Could be I wasn't in the system long enough for SYS user to be affected.
Has anyone seen this before. All versions being run is 9.2A
MC Rate Issue.png (128 downloads)
#48540 - 01/13/16 10:50 AM Re: Multicurrency 9.2A Rate goes to zero [Re: GT]
Two days ago one of my clients had a similar problem in AR v9.2. They did a revaluation. The listing was perfect but when they posted the revaluation the revaluation rate was set to 0.00000 and the date to 12/31/1899, so the home currency was set to $0.00. Checking the database the last revaluation rate and date fields were blank. As they didn't have a recent backup I did a new revaluation to restore the Home amount and asked them to make sure they do a backup before the next revaluation and call us back if the problem reoccurs.
#48564 - 01/14/16 06:29 AM Re: Multicurrency 9.2A Rate goes to zero [Re: Douglas Dickie]
Hi Doug,
There is no option for that in OE so do you think if I do it in AR it will trickle to OE and solve the problem?
#48580 - 01/14/16 11:56 AM Re: Multicurrency 9.2A Rate goes to zero [Re: GT]
Nope, all it will do is correct the Home amount in AR and send the mathematical adjustment to Unrealized Exchange Gain/Loss account. Most likely the sales account will be missing the Home current amount for this invoice.
For OE you could trying doing a credit note and re-invoice to see what happens. You would want the credit note to also have a 0 exchange rate (to match the invoice) and the new invoice to have a proper exchange rate. If this works then do the same thing on the live data. If it doesn't work then your client will either have to live with it or have a database repair (DBR) done. With a DBR you will also need to fix the GL entry with a manual GL adjustment entry.
#48675 - 01/18/16 04:18 AM Re: Multicurrency 9.2A Rate goes to zero [Re: Douglas Dickie]
Thanks Doug,
Will have Softrak look at their data.
#49540 - 04/07/16 01:16 PM Re: Multicurrency 9.2A Rate goes to zero [Re: GT]
Victor B. Offline
Loc: Toronto, ON, Canada
We have the same problem after conversion that happened 3 days ago. It affected only 3 users in 2 different datasets. It looks like it is user profile related problem.
Does anyone know how to fix this
Regards
Victor
Victor
#50325 - 06/17/16 01:48 PM Re: Multicurrency 9.2A Rate goes to zero [Re: Victor B.]
Heather Mac Offline
is there a fix for this issue yet??
#50326 - 06/17/16 02:03 PM Re: Multicurrency 9.2A Rate goes to zero [Re: Heather Mac]
Yes, there was a Hotfix released: Adagio OrderEntry 92A (160201) HF
You should contact your Adagio consultant to get this release.
1 registered (1 invisible), 90 Guests and 2 Spiders online.
1865 Members
14509 Topics
27 28 29 30 31
