#4725 - 03/08/05 09:37 PM period formula in Crystal
Kate Spontak Offline
Loc: New Jersey
In Crystal Reports for Adagio, I created a CrossTab report to show sales by customer by period for the year
The formula for period is:
Year({QI62A History Headers.Date}) &' '&
(if (Month ({QI62A History Headers.Date}))<=9 then
' 0'&Month ({QI62A History Headers.Date}) else
''&Month ({QI62A History Headers.Date}) )
In the original report the period returned by this formula looks like this 2004 01
When I update the report selection formula to a new year, the formula changes and shows as 2004.00 01.00
Can anyone tell me how to correct this.
#4726 - 03/10/05 01:57 PM Re: period formula in Crystal
Hi Kate,
If you are looking to format the date that certain way on the printed report, perhaps just change the format rather than use a formula?
- Put the Date field onto your report
- Right-click and choose Format Fields
- Go to the Date/Time screen and at the bottom, click Customize.
You'll get into a screen where you have full control over how dates print.
- Change the order to YMD
- Select None for day to not print the day
- Use a space for the first separator instead of /
- Delete the second separator
I'm surprised you're not getting errors with your formula because the Year function outputs a number, not a string. Perhaps use ToText(Year(Date),0) to remove decimals?
#4727 - 03/10/05 08:39 PM Re: period formula in Crystal
Loc: New Jersey
Thanks for the suggestions.
The first did not work because it separates day by day, instead of period by period.
The second did work when I applied it to both year and month.
ToText (
Year(
{QI62A History Headers.Date}),0
(if (
)<=9 then ' 0'&
ToText (
Month ({QI62A History Headers.Date}),0
) else ''&
ToText (Month ({QI62A History Headers.Date}),0 ) )
When I tried it without using ToText for the month, the result was 2,005 01.00
Although I could hide the trailing decimals by shortening the field, that comma in the year looked mighty strange. I had to change the format for number fields to eliminate the comma.
0 registered (), 63 Guests and 3 Spiders online.
