#46927 - 08/19/15 07:51 AM Crystal Reports Custom Reports AR 150625
Tony Martin Offline
Loc: Chatham, Ontario, Canada
I have reports designed for AR 9.2A (150625) that run fine on my install.
When transferred to the customer, pressing "preview" after selecting the custom report results in an "Unspecified Error".
I just noticed the AR about screen says it is AR 9.2A (150701) ??
Any ideas?
Tony Martin
Code 6 Programming
519.359.0918
#46947 - 08/20/15 11:35 AM Re: Crystal Reports Custom Reports AR 150625 [Re: Tony Martin]
Samuel Kopstick Offline
Hi Tony:
I likewise have had this problem, and reported in on the Forum a number of weeks ago.
Problem is, I sent the data and reports to Softrak and they are able to run the reports without the error message, but I still cannot run them from within Adagio 9.2.
The reports that bomb-out in Adagio work fine when I run them from Crystal.
This issue is not resolved for me yet.
Samuel Kopstick
S Kopstick & Associates Inc
Toronto, ON
#46953 - 08/20/15 01:54 PM Re: Crystal Reports Custom Reports AR 150625 [Re: Samuel Kopstick]
Tony Martin Offline
Hi Samuel:
Did you see my note about the version...what version does your AR report?
Tony Martin
Code 6 Programming
519.359.0918
#46954 - 08/20/15 02:11 PM Re: Crystal Reports Custom Reports AR 150625 [Re: Tony Martin]
I am running the reports accessing tables from OE & AR.
The AR is 9.2A(150410).
The OE is 9.2A(150729)
(I am trying to use the most-current versions.)
Samuel Kopstick
Toronto, ON
#46958 - 08/20/15 02:41 PM Re: Crystal Reports Custom Reports AR 150625 [Re: Samuel Kopstick]
A common problem with Crystal Reports "works for me and not the client" is the printer driver. Try printing to AdagioPDF.
#46961 - 08/20/15 03:33 PM Re: Crystal Reports Custom Reports AR 150625 [Re: Douglas Dickie]
Tony Martin Offline
I've tried printing to AdagioPDF ...same result.
Tony Martin
Code 6 Programming
519.359.0918
#46967 - 08/20/15 03:56 PM Re: Crystal Reports Custom Reports AR 150625 [Re: Tony Martin]
Hi Tony,
Other possible differences may be the dictionary used for creating the report (ie you have a dictionary in \softrak\dict that your client does not have), or that you have MS Visual C++ Runtime versions on your workstation that your client does not have. Perhaps there are other system files or other differences apart from these.
Are you creating CustomReports or ModifiedReports to run from Adagio? Or is PrintTool being used to print the custom report? That might make a difference, particularly with the ODBC connection but perhaps also the dictionaries.
I presume that your client is able to print the Standard Reports in Adagio 9.2A successfully and it is just the custom-written reports with a problem.
I could not locate a particular reason for the 'Unspecified Error' message.
#46978 - 08/21/15 08:37 AM Re: Crystal Reports Custom Reports AR 150625 [Re: Softrak Support]
I changed the report printer in the Crystal Report to AdagioPDF & re-saved the file.
(And just to be sure, I uninstalled on my laptop the ODBC and re-installed.)
The report is saved to C:\SOFTRAK\Receivables\CustomReports
In Adagio AR, I ran the report twice from two separate companies (different clients' data), but the end result is that we still receive: "Unspecified error"
When I run the same report from Crystal, the report runs properly.
Samuel Kopstick
Toronto, ON
#47033 - 08/28/15 07:24 AM Re: Crystal Reports Custom Reports AR 150625 [Re: Samuel Kopstick]
Tony Martin Offline
Tried printing with PrintTool....prints fine when using "saved data", but crashes when I try to refresh.
I'm thinking it's one of two things:
Parameters: Report has parameters. They aren't fancy, don't look up info and aren't cascading.
ODBC Driver: I've noticed there are some things I can't do in Crystal while using the Adagio ODBC (like using formulae in linking), perhaps one of the Crystal functions I've used (inadvertently) is causing the ODBC read to fail.
As an immediate solution, this client is buying Crystal for themselves and I will recreate the report on site.
I'll keep you posted...
Tony Martin
Code 6 Programming
519.359.0918
#47034 - 08/28/15 07:59 AM Re: Crystal Reports Custom Reports AR 150625 [Re: Tony Martin]
I doubt this will solve the problem, but you shouldn't be saving the data with the report.
If you want, you can upload the data and the RPT and we can try and recreate the problem here.
0 registered (), 237 Guests and 2 Spiders online.
14617 Topics
