#46664 - 07/23/15 09:21 AM PO Additional Item Description
You can feed the 4 additional information fields from the item master to the details of a PO by right-clicking on the item, selecting Additional Item Info, and clicking OK.
However, the fields do not feed if the first line is blank. I don't think this is the desired result. Unless I'm missing something.
#46670 - 07/23/15 12:14 PM Re: PO Additional Item Description [Re: Steve Schwartz]
Steve:
Not likely the desired result but how is the first line blank (like is it an empty comment line)? If so then is a comment line with something in it okay?
#46671 - 07/23/15 12:18 PM Re: PO Additional Item Description [Re: Douglas Dickie]
Can you put a "." in the first line so it is not "blank", but also not very prominent?
#46676 - 07/23/15 07:02 PM Re: PO Additional Item Description [Re: Retired_Guy]
I could put a "." in the first line but I am not the user, and it is not something the user will think of doing. That's what I call a non-intuitive workaround.
This client has designated lines 2 and 3 for specific purposes, and often doesn't enter anything in the first line. Really, that shouldn't cause the PO additional lines to not show.
I guess what I'm suggesting is that the additional lines be saved to the PO even if the first line is blank.
#46692 - 07/24/15 08:29 AM Re: PO Additional Item Description [Re: Steve Schwartz]
Hi, Steve,
This issue was written up for R&D yesterday. Others are suggesting a workaround for you until this can be resolved.
14630 Topics
