#46680 - 07/24/15 05:45 AM Financials - Worksheets per workbook
Just a quick question can you tell me if 16 worksheets is the maximum of sheets that is assigned to any one workbook, or financial statement.
I know you can do page breaks in any worksheets a number of times over but a client wanted each department on a worksheet of it's own but has 16 and is unable to create another. The option simply isn't there. It says delete worksheet but no option to insert as usual.
#46682 - 07/24/15 07:53 AM Re: Financials - Worksheets per workbook [Re: GT]
Lauren Stief Offline
Adagio Padawan
Loc: Waterloo, ON
Hi GT,
You are correct 16 is the maximum number of tabs (worksheets). See here for more information http://softrak.com/ubbthreads/ubbthreads...lts_f#Post44128
Lauren
Lauren Stief
Adagio Solutions and Support
1-800-540-3164
#46683 - 07/24/15 08:02 AM Re: Financials - Worksheets per workbook [Re: Lauren Stief]
#46684 - 07/24/15 08:05 AM Re: Financials - Worksheets per workbook [Re: GT]
Hi Ishana,
Rather than have each department on a separate sheet, you should only need one sheet and then select the department you want to view from the department drop down.
You can also create a statement group that will print each of them in turn for a combined set.
Having each department on a separate tab is the way you would do this in Excel, where there is no way to just "toggle" the department.
14658 Topics
