#46579 - 07/20/15 04:33 AM OE footer spec fields
Most of the %F spec fields will print on either the Header or Footer of a spec form. For example, %F1, the total invoice amount, prints fine at the top as well as bottom of a form.
But for some reason %F24 and %F26, total weight fields (shipped and ordered) print as 0 when placed at the top of the form.
Is this by design, or accidental? A client needs to put the total weight at the top of a form (as part of a tear-off shipping label) and right now they have to print it at the bottom and then hand-write it onto the label.
#46617 - 07/20/15 04:36 PM Re: OE footer spec fields [Re: Steve Schwartz]
Michael Mulrooney Offline
The %F specs ( footer specifications ) are from the O/E Sales Order Header file and the ones that display zero are from O/E Sales Order Detail file and are calculated while they are being printed.
You can verify that by using Gridview and looking at the available fields in those tables or use the DataDictionaryExporter and send the OE tables to Excel.
