#46419 - 07/08/1512:53 PMExporting vendors in AP 9.2A
Patricia B.
AP 9.2A 150609.
If you try to export Vendors and save the file anywhere out of the data folder, it produces an Access Violation error. It has been tested in different environment and different databases.
I was able to re-produce this problem, but noticed you can work around it if you type in the filename, even if it doesn't already exist. The problem seems to be with the validation of the path.
#46439 - 07/09/1501:12 PMRe: Exporting vendors in AP 9.2A
[Re: Softrak Support]
Patricia B.
I realized that the error occurs only, browsing for the location, if you don't enter the extension when the file doesn't exist; either in the data folder or somewhere else.
Edited by Patricia B. (07/09/1502:07 PM)
