#464 - 02/16/00 01:56 PM Re: datacare error, urgent need of help
Hi, Dewi:
DataCare does a more thorough check of data than both the DIC and FixIt by also checking on keyed and flat files if you have selected to check these fields in the configuration area of DC.
DataCare is reporting that your ICILOC'1 has errors, specifically in your "item number/loc code" area. Phase 1 errors are not normally fixable, and may need data repair done on the files in question.
DC should give you a choice to fix some errors, if they can be fixed. If it has not given you this choice, or if it stopped checking due to the errors it found (will only do this in the case of Phase 1 errors) then you will require your data to be fixed.
If you do not have options for data repair, you could call your Dealer. Softrak offers database repair as well, you could call our DBR Department for a quote, if necessary.
#466 - 02/18/00 02:52 PM Re: datacare error, urgent need of help
Hello Dewi,
This file is the Quantity by Location file.
You should not just restore the one file. If you are going to restore date, you should restore the IC dataset and any related datasets (OE, PO, IR, for example).
