#45898 - 05/28/15 07:55 AM Error converting datapath to UNC, Error Code 1217
Ryan Offline
Loc: Manitoba, Canada
I am getting the following error when I try to print something from Payables and Receivables for one of our businesses.
I then get the following:
Unknown Database Connector Error
Error in file CRCPOST
I can print from Ledger and Invoices. The other business prints fine in all modules.
RD
Edited by Ryan (05/28/15 08:17 AM)
#45900 - 05/28/15 09:10 AM Re: Error converting datapath to UNC, Error Code 1217 [Re: Ryan]
Most likely this will be fixed by launching the file called CRRuntime_32bit_13_0_9.msi in the \Softrak\System\CR_InstallCommon folder and following the prompts. This should have installed automatically but sometimes for reasons unknown it doesn't.
Let us know.
#45904 - 05/28/15 09:46 AM Re: Error converting datapath to UNC, Error Code 1217 [Re: Steve Schwartz]
Ryan Offline
Tried reinstalling the CRRuntime and no luck. Still unable to print from Receivables and Payables for the one business. Everything else is fine.
#45905 - 05/28/15 10:23 AM Re: Error converting datapath to UNC, Error Code 1217 [Re: Ryan]
Hi, Ryan,
Please refer to this post: http://softrak.com/ubbthreads/ubbthreads.php/topics/45465#Post45465
Try using UNC's in all places on your module shortcut (i.e. target, datapath, etc.).
#45909 - 05/28/15 10:47 AM Re: Error converting datapath to UNC, Error Code 1217 [Re: Softrak Support]
Ryan Offline
i don't have access to that post.
#45911 - 05/28/15 10:58 AM Re: Error converting datapath to UNC, Error Code 1217 [Re: Ryan]
Okay, I'll paste it here:
"We had to use UNC for shortcut, target and data path to make it work. Just doing the shortcut resulted in the same error.
We also found that UNC just for the data path and mapped drive for the shortcut removed the printing error. Go figure."
If you're uncomfortable using UNC's at all, I'd recommend involving your Adagio consultant.
0 registered (), 206 Guests and 7 Spiders online.
14576 Topics
