#45625 - 05/06/15 10:06 AM Slow Login After Moving to Virtual Server
JWH Offline
John Hancock, CPA
Loc: London, ON
We are having an issue with slow login times regardless of module and/or database. The user in question had their Adagio programs moved to a "virtual server" (all mappings etc stayed the same). The data was moved some time ago without issue.
The issue now is very slow log ins. Specifically 3 1/2 minutes to actually make the connection. Once logged in no issues working with the data only logging on.
Opportunistic locking is enabled and we have doubled checked the system.ini file to make sure pointing to the correct path.
Any suggestions?
John Hancock
John W. Hancock & Assoc. Ltd.
#45626 - 05/06/15 11:17 AM Re: Slow Login After Moving to Virtual Server [Re: JWH]
John:
Make sure that your antivirus isn't aggressively checking Adagio. You must set your AV to exclude checking the Softrak or data folders.
#45633 - 05/06/15 07:11 PM Re: Slow Login After Moving to Virtual Server [Re: Douglas Dickie]
Scott/John:
I agree with Doug completely. Two weeks ago a client reported similar load time issues. When I asked when the performance problem started, it became apparent that it coincided with the installation of new A-V software. As soon as the software was uninstalled, performance returned to normal.
#45635 - 05/06/15 08:31 PM Re: Slow Login After Moving to Virtual Server [Re: Bruce Gardner]
Antivirus would be my first guess. If that isn't the cause, then you should look at the search paths to see if some offline UNC is being referenced which would be resulting in a time out for every EXE and DLL load on startup.
#45640 - 05/06/15 10:08 PM Re: Slow Login After Moving to Virtual Server [Re: Retired_Guy]
Terry Pennock Offline
Terry
Loc: Campbell River, BC
Hi John,
We use a virtual server for our Adagio Applications and login is not slow.
As a test, create a new desktop icon to access the application and see if that helps.
Terry
IMS Island Microsystems Ltd
250 287-9874
terry@islandmicro.com
www.islandmicro.com
IMS Applications:
CounterSales . JobTracker . POTracker . LabelPrint . LotTracker . SerialTracker . IMScheduler . ReportGen
JobTracker can now use ServiceTracker to track jobs performed on Equipment and Machines.
Call for more information on our applications or to arrange a Demo.
#45645 - 05/07/15 07:32 AM Re: Slow Login After Moving to Virtual Server [Re: Terry Pennock]
JWH Offline
John Hancock, CPA
Loc: London, ON
Hi Guys,
Thanks for all of your suggestions. Much appreciated. I will pass along info to the IT person and have a look.
I will keep you posted.
Thanks again everyone.
John
John Hancock
#45646 - 05/07/15 08:12 AM Re: Slow Login After Moving to Virtual Server [Re: JWH]
JWH Offline
John Hancock, CPA
Loc: London, ON
Hi Again Guys,
Just checked with their IT person and the anti virus was the culprit! Thanks again and much appreciated your input. Log in times are now back to normal.
Thanks again guys. Your input was/is greatly appreciated.
John
John Hancock
0 registered (), 102 Guests and 0 Spiders online.
14598 Topics
