#43384 - 11/03/14 08:10 AM Editing Filters in Gridview
jasrod Offline
Stranger
Loc: Toronto Ontario Canada
I recently created a new view, to extract data from our purchase order module. After a month or so of use, I realize that I'd like to make some enhancements. However I no longer able to edit filters, add calculated columns, etc. by using the pull down menu. Can someone explain how to edit the view after it has been created? If I view the filter toolbox, and then right click the filters listed, I can bring up the edit filter dialog box. However I still can't edit calculated columns, and the edit filter option is still unavailable from the pull down menu. Is there another procedure to be able to edit a view after it has been created and run?
#43385 - 11/03/14 08:40 AM Re: Editing Filters in Gridview [Re: jasrod]
You must launch GridView from a shortcut to be able to edit the View.
#43386 - 11/03/14 09:06 AM Re: Editing Filters in Gridview [Re: Retired_Guy]
jasrod Offline
Stranger
I thought that was the problem, because I've run into this before. When I close down all other programs, and launch from the shortcut I get the same problem.
This is the listed target from the shortcut:
K:\Softrak\GVWIN\GVWin.exe
Am I missing something?
#43387 - 11/03/14 09:35 AM Re: Editing Filters in Gridview [Re: jasrod]
Lauren Stief Online   content
Adagio Padawan
Loc: Waterloo, ON
If you don't have "/c" in your target line then you won't be able to edit your view. Your target line should read like this: "K:\Softrak\GVWIN\GVWin.exe /c"
Lauren Stief
Adagio Solutions and Support
1-800-540-3164
#43388 - 11/03/14 09:45 AM Re: Editing Filters in Gridview [Re: Lauren Stief]
jasrod Offline
Stranger
Thank you. The "/c" fixed my issue. Can anyone chime in on what the "/c" is for, and where one might be able to find a list of useful switches?
Regards
#43390 - 11/03/14 12:15 PM Re: Editing Filters in Gridview [Re: jasrod]
Samuel Kopstick Online   content
Start up GridView.
While in GV, press F1 to call up the Help screen.
Click on the "Search" tab on the upper-left side of the screen, and enter: command line.
Press <ENTER>.
Double-click on the first item below: Command Line Parameters - it should list all the various switches.
Samuel Kopstick
S Kopstick & Associates Inc
Toronto, ON
#43393 - 11/03/14 01:00 PM Re: Editing Filters in Gridview [Re: Samuel Kopstick]
"/c" = "Change".
3 registered (Samuel Kopstick, Brian Stief, Lauren Stief), 144 Guests and 0 Spiders online.
14625 Topics
