#4325 - 09/21/04 01:08 PM Edit fields are overlapping GL
When I went to enter a batch entry, the fields are overlapping. The debit and credit fields are overtop of the account coding fields. Other menus are not displaying correctly either.
I did a data integrity check and also tried restarting the computer. Any ideas!!!???
#4326 - 09/21/04 01:40 PM Re: Edit fields are overlapping GL
Don Wise Offline
Adagio Expert
Loc: Ottawa
Hi Kim,
Check your windows settings to be sure that you are not running with large fonts. In XP it is under display properties, appearance.
Don - Westboro
#4327 - 09/21/04 03:49 PM Re: Edit fields are overlapping GL
quote:
Originally posted by Don Wise:
Hi Kim,
Don - Westboro
Thanks Don,
It was set to normal. It is not the font that seems big, it just seems squished together.
Kim
#4328 - 09/21/04 05:11 PM Re: Edit fields are overlapping GL
Ralph Allan Offline
From a previous note in this forum . . .
Another place to look in Windows XP is the DPI (dots per inch) resolution in the Advanced area of the Display settings
Right mouse click on an empty area of your desktop and select Properties. From the Display properties tab select the Settings screen. At the bottom right, click the Advanced button.
From here, on the first screen that comes up (General), there is a DPI resolution that should be set to Normal size. If it is Large size or Custom, then this can also throw off window orientation.
Also note on this screen in the bottom half is the place to set when Windows will apply new display settings (ie is a reboot required). Perhaps after changing settings you had to reboot the computer for them to take effect.
#4329 - 09/25/04 02:00 AM Re: Edit fields are overlapping GL
Thanks Ralph!! That worked. It was set to large, I changed it to normal and everything is appearing properly now!!
14617 Topics
