#42621 - 07/31/14 01:45 PM Need to Export Stock Count Work Sheet
chinmook Offline
Edward Chris Chin-Mook
Loc: Jamaica
Dear Team,
Urgent need of your combined wisdom.
I am trying to export a Physical Count Worksheet for a location to check back count by "Picking Sequence".
When I export I am getting (-1) where the count information should be ...
I have staff waiting on a response.. The Reconciliation Report does not print by "Pick Sequence...
Regards
Ed
Edward C Chin-Mook
876-754-7444
876-754-5513
#42623 - 07/31/14 02:45 PM Re: Need to Export Stock Count Work Sheet [Re: chinmook]
Hi Edward,
Stock counts are not stored in the system. You can export the Quantity on Hand data value for a specific location, sorted by Pick Sequence, but it is not possible to print/export the values previously counted.
If you export the Stock Count field to the Excel workbook, it is by design to pre-fill this column value with -1, so that you don't accidentally re-import a different value (such as zero). The purpose of this field is for someone to do the count and replace the -1 with the physical value. Then when importing this Excel file back into Inventory, the appropriate count adjustments can be made.
There are 2 'ShowMeHow' videos on how to do physical inventory in IC, one the import way and another the manual way.
#42624 - 07/31/14 02:49 PM Re: Need to Export Stock Count Work Sheet [Re: Softrak Support]
chinmook Offline
Loc: Jamaica
But I failed to say I was using an older version. (Current I.C Version does what I need.)
Edward C Chin-Mook
876-754-7444
876-754-5513
#42625 - 07/31/14 03:35 PM Re: Need to Export Stock Count Work Sheet [Re: chinmook]
Hi Edward,
If the current version does what you want, wouldn't the solution be to get the current version?
Rows in Excel sheets can be re-sorted if that is all that needs changing.
