#41975 - 06/17/14 05:37 AM Purchase Orders 8.1D (140611) Calculated Quantity
doug Offline
Doug Parrington
Loc: Winnipeg
Does anyone know why when I auto generate a purchase order with the following settings, the computer does not calculate the quantity correctly for non stock items (no min/max/reorder)
quantity on SO is 24
quantity on Hand is 0
quantity on PO is 0
auto generating for Inventory with following selections:
Primary vendors
Below minimum
Up to maximum
Calculated quantity
Computer orders 23
Thank You
Doug
#41977 - 06/17/14 07:39 AM Re: Purchase Orders 8.1D (140611) Calculated Quantity [Re: doug]
How can you be ordering a "non stock" item?
#41978 - 06/17/14 07:50 AM Re: Purchase Orders 8.1D (140611) Calculated Quantity [Re: Retired_Guy]
doug Offline
Doug Parrington
Loc: Winnipeg
We use the term non stock to refer to Items we do not stock on our shelves but will order in if a customer requests it. We treat them the same as a stock item but keep zero on hand. We still use Purchase Orders 8.1B because it orders the correct amount.
Doug
#42058 - 06/24/14 03:06 PM Re: Purchase Orders 8.1D (140611) Calculated Quantity [Re: doug]
I have duplicate this issue and forwarded it to R&D.
In the meantime, if you set the Purchase qty to Above maximum, it will calculate the correct quantity.
#42090 - 06/26/14 08:03 AM Re: Purchase Orders 8.1D (140611) Calculated Quantity [Re: Softrak Support]
doug Offline
Doug Parrington
Loc: Winnipeg
Thank you for looking in to this. Unfortunately if I order to above maximum I will have to reduce the maximum on over 1200 items or we will over order for every item in our warehouse and then have to increase them again when problem is fixed.
Doug
#42092 - 06/26/14 08:37 AM Re: Purchase Orders 8.1D (140611) Calculated Quantity [Re: doug]
I also had success with setting a maximum of 1 on the non stock Item. With this setting and your generate options, I get 24 when I choose Purchase qty Up to maximum and 25 if it is Above maximum.
#43200 - 10/09/14 04:59 AM Re: Purchase Orders 8.1D (140611) Calculated Quantity [Re: Softrak Support]
doug Offline
Doug Parrington
Loc: Winnipeg
I just upgraded PurchaseOrders to 8.1D (141006) and this problem has not been resolved in this service pack. frown
Doug
#43202 - 10/09/14 08:01 AM Re: Purchase Orders 8.1D (140611) Calculated Quantity [Re: doug]
Hi, Doug,
This issue did not make it into this SP for PO. Unfortunately, we aren't able to include everything in every release.
I have updated the issue with your comments.
#43204 - 10/09/14 11:33 AM Re: Purchase Orders 8.1D (140611) Calculated Quantity [Re: Softrak Support]
doug Offline
Doug Parrington
Loc: Winnipeg
Thank you
Doug
#44798 - 03/04/15 09:54 AM Re: Purchase Orders 8.1D (140611) Calculated Quantity [Re: doug]
Hello Doug,
This Auto Generate issue has been fixed in PurchaseOrders 92A (150217)
1 registered (Eva_Froese), 106 Guests and 8 Spiders online.
14580 Topics
January
