#41751 - 05/30/14 10:47 AM PO; Sundry Items; Reports
SupportGuy Offline
Loc: Victoria, BC, Canada
I would like to print my collection of sundry items.
Reports->General Reports->Sundry Items, entire range. If I click Print or Preview, a progress dialog appears briefly, but I get no output.
The sundry item list is populated as I regularly create POs using those items.
Any help would be appreciated.
#41752 - 05/30/14 10:51 AM Re: PO; Sundry Items; Reports [Re: SupportGuy]
Although this doesn't explain why the report is not working, why not just click on the green X with the Sundry Item list open, and it will export the list to Excel. You can choose which columns you want to see on the list.
If you don't want the whole list, but just a portion, you can use the Smartfinder (F6) to filter the list and only send the portion to Excel (and you can also print from the Smartfinder list).
If you don't see a green X, that is an option you will need to change under User Setup.
#41755 - 05/30/14 11:01 AM Re: PO; Sundry Items; Reports [Re: Steve Schwartz]
Hi, Steve & Support Guy,
The fact that the Sundry Items report doesn't produce any output was just reported to us this week. It will be fixed for the next release of PO.
#41756 - 05/30/14 11:09 AM Re: PO; Sundry Items; Reports [Re: Softrak Support]
SupportGuy Offline
Thank you both. I took Steve's advice which will work out just fine.
#42119 - 06/26/14 01:37 PM Re: PO; Sundry Items; Reports [Re: SupportGuy]
This was also fixed on the PO 81D (140611) Service Pack!
0 registered (), 148 Guests and 1 Spider online.
1869 Members
14602 Topics
