#41189 - 04/21/14 07:34 PM Deleting OE Miscellaneous Charges
Hello Support:
A client wants to delete an OE Miscellaneous Charge from the master list. They receive a message indicating that Day End must be run first. Yet even after running Day End and clearing the Audit Report, they are still denied with the same message.
Question: Is there something else that needs to be run or cleared?
OE: 8.1F (13-07-08) Thank you.
#41217 - 04/22/14 01:47 PM Re: Deleting OE Miscellaneous Charges [Re: Bruce Gardner]
Hi, Bruce,
Have you seen this behavior yourself? I ask because I just tested using OE8.1F(131106) and (130708) without issue.
#41220 - 04/22/14 02:45 PM Re: Deleting OE Miscellaneous Charges [Re: Softrak Support]
Hi Support:
Yes, I have. I was skeptical myself but after being told, patiently, of this issue by the client for the past 6 months, I decided to test it myself. I connected remotely, made a copy of the data, ran OE Day End and received the same results as they described.
I was hoping you knew of a secondary check being made in the background. If not, I'll get a copy of their data and see what I can discover.
#41279 - 04/28/14 10:02 AM Re: Deleting OE Miscellaneous Charges [Re: Bruce Gardner]
Hi Bruce,
Check for an Invoice or Credit note dated in the future. If they have a document that does not have Yes for the Costed Status, it is preventing the deletion.
#41285 - 04/28/14 03:07 PM Re: Deleting OE Miscellaneous Charges [Re: Softrak Support]
Thank you for the suggestion. I'll look for that when I get a copy of the data again.
#41383 - 05/02/14 11:09 AM Re: Deleting OE Miscellaneous Charges [Re: Bruce Gardner]
Support:
Thank you. You are correct - they routinely date invoices a few days into the future.
0 registered (), 177 Guests and 6 Spiders online.
1874 Members
14564 Topics
Max Online: 630 @ Yesterday at 02:28 AM
