#41169 - 04/17/14 02:16 PM Retrieving data from Simply Accounting
larry Offline
SLCC
Loc: whistler
When I retrieve data from Simply Accounting to FX Pro V9.0B instead of the budget data getting over written. It is added to the existing budget data. For example if I retrieve the data twice the budget data will be doubled. I have been getting around this by retrieving data into a new data file each time.
Is there a simple solution to this issue.
thanks,
#41171 - 04/17/14 03:09 PM Re: Retrieving data from Simply Accounting [Re: larry]
Actually, The simplest solution (no pun intended) is to set your budgets up in FX the way you would like and not retrieve the budgets from Simply at all.
14617 Topics
