#40551 - 03/07/14 07:13 AM Error 1.... delete temporary system cheque file
Janelle Offline
Loc: St. Lucia
Hi All -
A user had a batch in AP with 2 cheques. The first one printed fine, then the error "Error 1 occurred when attempting to delete temporary system cheque file" appeared. Has anyone seen this issue before? we are running AP Ver 8.1E.
Thanks.
Rgds
Janelle
#40552 - 03/07/14 07:17 AM Re: Error 1.... delete temporary system cheque file [Re: Janelle]
This is usually caused by the user having insufficient rights in the data directory. Have you recently installed a new server or "IT guy"? wink
Users need all rights in the Adagio Data Folder.
PS - I hope we'll see you at the upcoming Adagio Academy on your beautiful island.
#40554 - 03/07/14 09:07 AM Re: Error 1.... delete temporary system cheque file [Re: Janelle]
BAMPH Offline
Paradise is perspective
Loc: Christ Church, BARBADOS
Hi Janelle,
While I have not seen that specific one before, I’ve seen some that are quite similar. I would say that the two most likely causes are:
1. The system is unable to delete a temporary file due to some process not having closed the file properly
2. The user does not have the correct rights
In your case, I very much doubt that it’s 2 unless this is a new user or you've modified network security recently.
In the case of 1, sometimes simply exiting and restarting Adagio is enough and sometimes one has to restart the workstation that had locked the file or even the Server (that’s a pain). You could also look at clearing the user’s windows Temp folder.
Failing that we may have to look at manually deleting Adagio temp files from the Adagio data folder. If this is the case, let me know and I'll contact you directly.
Regards, Pete
Peter Banfield
BAMPH Consulting Services
Barbados
0 registered (), 75 Guests and 3 Spiders online.
14669 Topics
