#40232 - 02/17/14 09:41 AM Vendor style
JeanB Offline
Loc: Kelowna, BC
How do I clear the manual display style for vendors? I have a vendor filter that I want to have all the same style, but a majority of the vendors have a manual style assigned to them (for some reason the style for most is set as 'standard' although a few have other styles manually set for them). The automatic display style does not seem to override the manual style, and yet I can't clear the manual style so that I can apply the automatic style to all of a particular vendor filter.
Jean
#40233 - 02/17/14 09:54 AM Re: Vendor style [Re: JeanB]
Hi JeanB,
You are correct that the Manual style will over-ride whatever is Automatically assigned from the Filter generation.
If the number of vendors is too large to do this by editing manually, then the easiest way is to use the export and import process to update vendors. All you have to do is Export all vendors to either an Excel or CSV file, and only the Vendor code field, nothing else. Then create an Import Vendors template using this exported file that only Overwrites existing vendors, has just the Vendor code field to import, and a Default Field for the Manual style, set to blank.
Running this import will change all vendors to have a blank value for the Manual Style, meaning all Automatic Styles will be used for the vendor list and finder grids.
#40234 - 02/17/14 10:28 AM Re: Vendor style [Re: JeanB]
Hi Jean:
Use Support's recommendations for export/import if you plan to clear the Manual style from a large number of vendors.
If you are planning to do them individually, edit the Vendor, select the "Manual" field and press the [Delete] key on your keyboard. As you have already discovered, the drop-down list doesn't contain a blank.
#40235 - 02/17/14 10:32 AM Re: Vendor style [Re: Softrak Support]
JeanB Offline
Loc: Kelowna, BC
That worked great - thanks!!
0 registered (), 306 Guests and 3 Spiders online.
14676 Topics
