#39255 - 11/19/13 06:12 AM Printing Quotes
MikeS Offline
Loc: Concord, On
Good Morning,
Let me start by saying that I normally print quotes to a pdf and then email to the customer along with other documents.
But today I had about twenty quotes I had to resend to a customer and since I didn't need the other documents I decided to make use of the range send under Print Quotes in maintenance. Unfortunately I kept getting a nothing in range to print message. I tried a number of different combinations but nothing worked (all options got selected at least once). I'm wondering if there is some switch that I forgot to turn on.
I then emailed them individually using the Print button in Edit Quotes. Is it possible to have the default 'Send to:' be customer when in quotes, not billing?
SalesCQ 8.1C (121012)
#39260 - 11/19/13 08:07 AM Re: Printing Quotes [Re: MikeS]
Hi, Mike,
There must have been something not quite right in the selection criteria. For example, if you want everything to print you can accept the defaults and enable the options; however, you still need to select an Ending Date.
I can enter your suggestion for you.
#39262 - 11/19/13 08:26 AM Re: Printing Quotes [Re: Softrak Support]
MikeS Offline
Loc: Concord, On
Thanks very much.
I didn't realize that every ending field had to have a value. My goof.
1 registered (Bruce Gardner), 228 Guests and 0 Spiders online.
1869 Members
14600 Topics
