#39067 - 11/05/13 03:08 PM Failed JC import into A/P detail shows on vendors
Trevor Offline
Stranger
Loc: Port Alberni, BC
I was configuring a JC batch import template in A/P, and after 6 attempts was able to successfully import the detail required, now the vendor detail and cheque register contains 12 lines of invoices and adjustments. Any suggestions on how to clear this detail, a blank cheque run perhaps?
#39069 - 11/05/13 03:24 PM Re: Failed JC import into A/P detail shows on vendors [Re: Trevor]
Trevor:
Why are you importing from JC to AP? Transactions should be entered in AP where they naturally flow to JC.
To match up transactions in AP that net to $0.00 you can do a manual cheque for $0.00 and use it to pay the invoices and adjustments.
#39071 - 11/05/13 03:58 PM Re: Failed JC import into A/P detail shows on vendors [Re: Trevor]
Trevor Offline
Stranger
OK, thanks
1 registered (Brian_Shead), 171 Guests and 1 Spider online.
14675 Topics
