#3899 - 03/11/04 04:24 PM Re: Adagio Ledger 8 PTF, not installing?
The 'default' installation path is a value stored in the registry, and may not necessarily be the actual location of your programs. For example, Adagio may have been installed in two places; which one should be the default?
You should browse or enter the correct program location if it does not appear as the initial place. As noted in your message, \Softrak\Alwin is the program directory for Adagio Ledger, usually found on a root of a drive but it doesn't have to be. You can do a file search of ALWIN.EXE to find where your program is installed.
#3901 - 03/12/04 05:49 PM Re: Adagio Ledger 8 PTF, not installing?
Michael Mulrooney Offline
If you are starting Adagio Ledger from a shortcut then RightButton|Properties will tell you the Drive and Directory of the currently installed Adagio Ledger.
#3902 - 03/12/04 05:50 PM Re: Adagio Ledger 8 PTF, not installing?
Hello foamboy,
Our records indicate that you have Adagio Ledger installed. If you are running Adagio Ledger, then the file ALWIN.EXE must exist on either your network or local hard disk.
14630 Topics
