#38310 - 08/22/13 12:45 PM Crystal Reports blast
I designed a fairly complicated sales report, which prompts for a salesperson code. My client prints it to PDF and emails it to each salesperson monthly.
Is there a way to automate the process so they can generate multiple PDFs, one for each salesperson? Automating the actual emailing is a second issue, but first I want to know if it's possible to generate one PDF per salesperson.
I know how to do this with GridView using a batch file, but I don't know if there's an equivalent using Crystal Reports.
#38312 - 08/22/13 02:11 PM Re: Crystal Reports blast [Re: Steve Schwartz]
Steve:
PrintBoss can create a different PDF files for each Salesperson.
You just print the report to the PrintBoss driver and it will output different PDF files.
#38314 - 08/22/13 04:46 PM Re: Crystal Reports blast [Re: Patricia B.]
Hi Patricia
How will PrintBoss know to do that? Right now the report is about 50 pages long, with a page break after each salesperson, and there are five salespeople. The number of pages varies for each salesperson.
#38316 - 08/23/13 03:00 AM Re: Crystal Reports blast [Re: Steve Schwartz]
Steve:
Basically Crystal Reports has to have a page break on change of salesperson and you train PrintBoss to recognize each salesperson so that it generates a separate PDF file for each. Getting PB to email the report to each salesperson is easy.
We've done similar work both for our in house purposes and for our clients as well. If you would like us to create this solution for you please let me know and I'll give you a quote offline.
#38325 - 08/23/13 09:57 AM Re: Crystal Reports blast [Re: Douglas Dickie]
Ralph Allan Offline
Steve:
There is a really neat product called Visual Cut from Millet Software .
It can pick up fields in a report and "split" the report into multiple PDF files based on that field. It can also automatically email the separate reports to an email address picked up from the report. (It must be in Group 1 and can be suppressed.)
The author, Ido Millet, is at Penn State University and is very helpful.
Ralph Allan
Business Computer Centre
Prince George BC Canada
#38327 - 08/23/13 11:01 AM Re: Crystal Reports blast [Re: Ralph Allan]
Steve:
Further to Ralph's suggestion, there are a number of products that also do that. Here's one I've looked at but not used yet: PDFMachine Their "Ultimate" version is $99.00.
If you have the time to experiment and learn, these could be useful tools. But PrintBoss is proven in the Adagio environment so it may be the best use of your time.
#38328 - 08/23/13 01:05 PM Re: Crystal Reports blast [Re: Bruce Gardner]
Hi Ralph
You are not kidding, Visual Cut looks really neat. It doesn't hurt that the author is from Penn State, not too far from me.
Tell me if I am correct, in order for Visual Cut to perform its magic, I have to first generate the report with the option to save the data turned on, don't I?
#38329 - 08/23/13 06:58 PM Re: Crystal Reports blast [Re: Steve Schwartz]
Ralph Allan Offline
Actually, no. The Visual Cut interface calls the selected Crystal report and runs it, including, if needed, prompting for parameters.
Ralph Allan
#38331 - 08/26/13 05:23 AM Re: Crystal Reports blast [Re: Ralph Allan]
Wow, Ralph, how come you didn't show us this product at Tips and Tricks!
I am going to be starting a new thread with a related question about emailing.
Thanks for the suggestion.
#38333 - 08/26/13 08:27 AM Re: Crystal Reports blast [Re: Steve Schwartz]
Ralph Allan Offline
Steve,
I thought about it, but I had not yet deployed it fully at the client, and so was not sure if I was going to run into unforeseen issues and did not want to present an untested solution. It is now deployed and has been in use for a while, and is working as it should.
There are a few minor, configuration issues that related to Adagio's use of the older Crystal Reports format. Call me about these if you wish.
Ralph Allan
0 registered (), 142 Guests and 4 Spiders online.
14579 Topics
January
