#37765 - 07/10/13 07:36 AM "Verify" problem - Invoices optional fields
Samuel Kopstick Offline
Using Optional Fields in Invoices.
We created an optional field, we set it to a Combo Box and we have entered values that we want the users to select from.
We set the “Verify?” to YES for Invoice batches.
This is working well when we enter our Invoices, most of the time. When a user forgets to enter the Optional Field value and they click the Close button or press ESC, we receive an error message: “A non-blank value is required”.
This is what should happen.
However if the user clicks the “x” in the top-right of the window to close the window, Adagio allows the Invoice to be closed and the Verify does not work.
As such, we have Invoices that were entered and we have some with no value in our Optional field, even though we have set "Verify?" to YES.
Samuel Kopstick
S Kopstick & Associates Inc
Toronto, ON
#37781 - 07/10/13 11:44 AM Re: "Verify" problem - Invoices optional fields [Re: Samuel Kopstick]
Hi, Samuel,
Yes, I can duplicate this behavior and am reporting it to R&D for you. Thank you for letting us know about the issue.
X'ing out of a record usually means that you don't want to save any changes to the record at all. Closing out of the record in IN is generally the way to say you want to save the record and this does trigger the message.
Edited by Softrak Support (07/10/13 12:04 PM)
Edit Reason: adding detail
1 registered (1 invisible), 98 Guests and 3 Spiders online.
14673 Topics
