#37419 - 06/18/13 04:53 AM Installing Ledger 9.1A
MER Offline
Loc: Ontario
I tried to install Ledger 9.1A, but the ledger version I am using is still 9.0D. The first time I installed it it went the way it always does, but when I then opened the Ledger it was still 9.0D. I tried again, and then it told me "This is not the proper upgrade for the version of Adagio Ledger found in the folder. You may install this upgrade into this folder if you can supply a valid SN and install code from a previous version." I cancelled the install and checked the version number because it sounded as if it would already be 9.1A. That just confirmed it was 9.0D. I ran the install again, using the original serial number and codes, and it let me install it again. However, when I open Ledger it is still 9.0D. Can someone help?
Mari
#37420 - 06/18/13 06:13 AM Re: Installing Ledger 9.1A [Re: MER]
My guess is that your shortcut is not pointing to the drive on which you are installing the program, but your Adagio consultant would be in a better position to hep you out.
#37421 - 06/18/13 06:21 AM Re: Installing Ledger 9.1A [Re: Retired_Guy]
MER Offline
Loc: Ontario
Thank you, I figured it out.
Mari
#37423 - 06/18/13 06:32 AM Re: Installing Ledger 9.1A [Re: MER]
What was the problem?
#37426 - 06/18/13 07:38 AM Re: Installing Ledger 9.1A [Re: Retired_Guy]
MER Offline
Loc: Ontario
Basically what you suggested - the Start Menu didn't update to point to the correct place. When I installed it for our second staff it did automatically update the icons for her. She's on Windows 7, I'm on XP, so maybe that caused the difference.
0 registered (), 257 Guests and 3 Spiders online.
14599 Topics
