#36739 - 04/30/13 08:37 AM Crystal Reports Install
Tony Martin Offline
Loc: Chatham, Ontario, Canada
Trying to install Crystal Reports for Adagio on a new Windows 7 machine.
Installing from wksetup: Just displays the UNC path and tells me to install from a drive letter...I've tried changing the UAC setting but no difference.
Installing from CD: No network drives showing in the drop-down field for Report Tables Drive.
Ideas?
Tony Martin
Code 6 Programming
519.359.0918
#36744 - 04/30/13 09:10 AM Re: Crystal Reports Install [Re: Tony Martin]
Is User Account Control enabled? That will hide network mapped drives.
#36748 - 04/30/13 10:37 AM Re: Crystal Reports Install [Re: Softrak Support]
Tony Martin Offline
All well and good until the installation reached the 'workstation' button...then I got the "install from a drive letter" message again!
UAC was 'off'...but I had to turn it 'on', then 'off' again (forcing a reboot) in order to see the drive letters.
Edited by Tony Martin (04/30/13 11:54 AM)
Tony Martin
Code 6 Programming
519.359.0918
#36749 - 04/30/13 11:03 AM Re: Crystal Reports Install [Re: Tony Martin]
Tony Martin Offline
Okay...to cut this short I've done a local install which went just fine.
Tony Martin
Code 6 Programming
519.359.0918
#36751 - 04/30/13 11:57 AM Re: Crystal Reports Install [Re: Tony Martin]
Tony Martin Offline
Now the regular reports aren't working, get the error message "Report [insert report path & name here] not found."
Tony Martin
Code 6 Programming
519.359.0918
