#36560 - 04/15/13 02:00 PM Inventory View Slow to respond
Steve_C Offline
Stranger
Loc: Arizona
Hi
We are using IC version 8.1D(120126) and having issues with very slow queries to viewing an item. The main list for the item inquiry comes up in a few seconds, but once you select an item to view it can take on the order of a minute or longer to display the item. This is happening on all of the machines that pull information from the IC database.
One thing that I have already tried is to remove the virus protection from one computer to test and verify that it was not the new program that was installed.
Any ideas?
Thanks!
#36564 - 04/15/13 05:58 PM Re: Inventory View Slow to respond [Re: Steve_C]
Is this new behavior or has it been happening for a while? If you copy your data local, how long does it take to open an item? Do you have images stored with your items?
#36615 - 04/17/13 02:49 PM Re: Inventory View Slow to respond [Re: Retired_Guy]
Steve_C Offline
Stranger
Loc: Arizona
This is a new behavior, on the order of a week or so. We did copy to a local machine and discovered that after
the first request for an inventory view the response was much faster. On the order of about 6 seconds or so where
as coming from the server it was greater than a minute response even with the same item. We do not store images
in our database which currently has about 28,000 items.
Thanks!
#36616 - 04/17/13 02:58 PM Re: Inventory View Slow to respond [Re: Steve_C]
OK - you are having a network issue, since it is running 10 times slower than your local drive. Either your Anti-virus is getting in the way, or you are having a hardware issue somewhere between the server and the workstation.
0 registered (), 200 Guests and 7 Spiders online.
14568 Topics
